Search In
  • More options...
Find results that contain...
Find results in...
Need help for what Power Supply to get or a Work Around
Hello, I’m new here and also to building computers, my friend gave me his old computer, which ran games okay on low/medium setting and I decided to buy a new gpu and upgrade ram with it, however I just realized I need a 8 pin pcie for the gpu but my mother board also needs a 4pin pcie for the cpu and a 24 pin from an atx power connector, please help with what I should do please, I’ll leave a link to my pcu calculator aswell: https://outervision.com/b/cOnhKV
Plug the things into PCPartpicker for the estimate and choose something appropriate from the fourm's PSU list:
What are your specs, including power supply? The 4 pin on the motherboard for the CPU is not a PCIe power connector, it is an EPS connector. If your power supply has an 8pin PCIe power connector, you should be good as long as the power supply is powerful enough to handle the graphics card.
 Share
