Search In
  • More options...
Find results that contain...
Find results in...
Running a 2070S and GTX 980 at the same time.
ItsFloopsy
 Share
So, I've done some reading and looked up some stuff but want to know if anybody has any personal experience running two different cards. No, I am not trying to get SLI like benefits.Simply another card to set as my encoder when i record or to use strictly to render so i can play games as I render. Any tips? Is it worth it? This wouldn't be a thought if i wasn't able to get a 980 for an ridiculously low price.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 5 2600X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap for what it had)
RAM: 16GB (2 x 8GB) of DDR4 GEIL Evo Potenza, OC to 3200Mhz
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: NONE, eveything works fine, no need to upgrade, stop telling me I need an SSD. Ok, things be slow sometimes.
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1920x1440@65Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz
Gateway VX900 CRT: 1920x1440@64Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
(Yes, I use a CRT and I prefer gaming on one)
Cooling: Grill with filter installed onto the front panel for air intake cooling with a 120mm Corsair ML120 fan and an old recycled 92mm cooler master(forgot model) fan for exhaust.
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
8 minutes ago, MadAnt250 said:
Literally the only video i didn't see lol. Funny enough was watching this as i got the notification. Thanks!
 Share
