Going from a 4k monitor back to 1440p or 1080p
Solved by MadPistol,
4k60 -> 1440p144 will feel amazing. Refresh rate is far more important IMO than resolution. I don't recommend going back to 1080p, because as you mentioned, the change will be jarring.
2
Vibes NoVibes ·
Posted in Troubleshooting1 -
5
kim921 ·
Posted in Build Logs4
play_circle_filled
Latest From Linus Tech Tips:
Why Do Youtubers Keep Destroying Companies - WAN Show April 19, 2024
