Search In
  • More options...
Find results that contain...
Find results in...
build help new pc (netherlands)
 Share
Go to solution Solved by faralind,
it is build and works perfect thanks everyone
Budget (including currency): around 2000euro (aprox 2200$)
Country: amsterdam/ the netherlands
Games, programs or workloads that it will be used for: games like starcraft 2 and spellforce 3 and some light photo edditing
Other details
need a new pc because first build is 20 years old and cant even handle win 10 or the games latest build is like 13 years old and broken (hardware problems).
just want a new build dont have a parts list yet looking for something non rgb still have a working screen keyboard and mouse so dont need them right now can upgrade later.
was planning to build it next month (june 2020) or close after
build some pc's before but am not that good with the compatability between parts
PC Builds
- Budget:2k euro
- Zip Code or Location:netherlands
- Specific Use:gaming/ lightroom
- Any preferred components?:
- Any spare parts you can re-use?:no
- Overclocking your processor?:no
- Need an Operating System?:no
- Need a Monitor? / Mouse? / Keyboard?:no
- Need a Wireless Card or Adapter?no
- Need Another Component? (Specify):no
Other Useful Info
- Preferred Case Features (Ex: Color, Side Window, Flashy):black, good filters, no rgb, good cable management
- Number of Monitors:1
- Other Info?:
previous build from 2013 was:
asus m2n sli deluxe,
antec nine hundred ultimate gamer case
hiper hpu-4k580
amd athlon64 x2 6000+
asus en8500gt silent
looking forward to any help u can give me
thanks in advance and if i need to add or adjust something
faralind
Wait for B550 if not building until next month. An Arctic Freezer 34 esports duo is more than enough for the cpu cooler.
Winter is Coming.
hiya thanks for the info i got the money together is it better to wait for that board ??? does the recent pricedrop affect the build ?? with that board is the rest the same ??
thanks in avance for any further info
gonna order monday should i go with the above system with the changed cooler ??? or should i wait for the other b550 suggested or change something after the recent pricedrop?
Make sure you quote people so that we can see your responses
The above link is a pretty great list, no issues there.
Primary PC:
i7 8086k (won) - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G2 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me.
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - dark mode Ubuntu (and Win7, cuz why not)
How many watts do I need? Seasonic Focus threadUserbenchmark (Et al.) is trash explained, PSU misconceptions, protections explainedgroup reg is bad
On 5/19/2020 at 2:43 PM, boggy77 said:
gonna order monday is this still the best build even with the amd pricedrop ltt talked about.
or should i wait till this board comes out around june 16th ?
thanks in advance for the info
The B550 boards will be cheaper, but may not be as feature-rich as the X570 and the price difference may not be very huge after all. Depends whether or not you need those features. By the looks of it you're only a light gamer, so 800 euro for a 2080 is pretty much overkill. Consider an older card, that'll still give you decent gaming but costs (less then) about half. If you still want to spend that amount, consider upgrading the proc and RAM (in equal measures), which will benefit editing/rendering video.
"You don't need eyes to see, you need vision"
(Faithless, 'Reverence' from the 1996 Reverence album)
Only just over a couple of weeks to go, so you might as well wait and see the B550 boards pricing etc before deciding.
Winter is Coming.
  • 2 weeks later...
ordered most of this list just the powersupply and the storage not available should i wait for them to be in stock again wich the site says at least 10 days because even the supplyers dont have em or are there replacements i can make for them and order today so that i can either build it this weekend or next week ???
thanks in advance
Edited by faralind
add thanks
14 hours ago, faralind said:
that one is also multiple days
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor €299.00 @ CD-ROM-LAND
Motherboard ASRock X570 Phantom Gaming 4 ATX AM4 Motherboard €164.95 @ CD-ROM-LAND
Storage Kingston A2000 1 TB M.2-2280 NVME Solid State Drive €126.00 @ Megekko
  Prices include shipping, taxes, rebates, and discounts
  Total €589.95
  Generated by PCPartPicker 2020-06-11 20:40 CEST+0200
does this kingston one works as well ?
yeah it's alright. see if you find the kingston KC2000 instead for a similar price, it's a bit faster than the A2000
  • 3 weeks later...
 Share
