Search In
  • More options...
Find results that contain...
Find results in...
H510 Compatible Power Supplies
Go to solution Solved by Applefreak,
Yes, your case is supporting ATX power supplies and the C series is ATX so they would be a perfect fit.
im just wondering would the NZXT C series 750W Gold Power Supply fit in a nzxt h510 case
PSU appears to be standard size, and case seems to have plenty of room around the PSA mounts, but since they are both nzxt products I;d email the support to be sure.
thanks for the help
thanks
