Search In
  • More options...
Find results that contain...
Find results in...
Trouble Routing 24 Pin
ShadowWrath5
 Share
Hey there,
Im having trouble routing my 24pin cable in my case due to the case layout and where the 24pin is on the board. I have the Phanteks Enthoo Evolv X PH-ES518XTG with the MSI Prestige x570 Creation. You can see in the pictures that I had to loop the cable because it wont bend towards the back of the case because the post for the sliding panels is in the way. I dont really want to remove the panel and leave a big gap in the back of my PC. Ive tried using a 90 degree 24pin adapter piece but I cant get it to fit without raising the board or removing the sliding panels due to clearance. I would like to try and keep my case in one piece if possible but I do need some kind of creative way to run this or a different type of adapter. Any help would be appreciated!
 Share
