Best wifi card ?
Goku1814
What budget? What router do you have? No point in getting a fancy wifi card if it has features your router doesn't, unless you want to get a new router with the wifi card. Also keep in mind using a wired connection is better, so only use a wifi card if you can't get an Ethernet cable to the computer.
