Search In
  • More options...
Find results that contain...
Find results in...
Too much thermal padte
I decided to clean my fan and my heatsink only to find out when I first installed the cpu I had applied to much thermal paste (See attachments). So I know it’s not good to reinstall your heatsink if you removed it and I’m scared I will push the thermal paste in the socket when I clean it. Any advice?
HOW MUCH FUCKING THERMAL PASTE DID YOU PUT  a gallon ?!?!?!? lmao
jokes aside just clean it normally and if you dont want to get rid of the thermal paste aside just leave it be
Phone: Pixel 3a (Purple-ish).
Build Log:
I think you are confusing resocketing a CPU with putting an integrated heat sink back on a CPU after deliding it, which is slightly more difficult and a bit more worrying.
I don't think taking out the CPU, cleaning it carefully and then replacing it is a concern.
Your larger concern is that when removing the CPU you may end up with paste in the socket.
However, in the pictures, just use some high strength 90%+ proof alcohol to clean it.
Start on the edges and move inwards, so the paste is pushed to the middle of the heatsink.  Come in at an angle and move upwards so the paste is not pushed down.
Use non-fibrous paper towels to clean it (not toilet roll which tends to break up too easily).
I have heard that coffee filters are good for this, though I have never used them.
I don't think you should have any issue cleaning it.
I think you drowned it, have you tried CPR?
NOTE: I AM NEVER ALWAYS RIGHT, BUT I AM HAPPY TO HELP ANYWAY I CAN
Tag me @WambleCropped or quote me so I can see your reply
My Rig: RTX 2060, R7 1700X, Samsung 860 500GB, Masterlite Liquid Cooler, Asrock Pro B540,16GB of RAM G.Skill 2133
PSU Tier List                    SSD Tier List                              Graphics Tier List
Oké status update, tried it but didn’t work, removed my cpu completely and cleaned everything again. Didn’t work Got a red warning light for my cpu, removed it again And know it does nothing. I’m afraid I might broke my cpu or my motherboards. Any thing that could help, don’t have another motherboard laying around to test or another cpu. I checked the cpu and saw no visible damage
Tried what ?
Don't tell me you removed the IHS ?
Build Log:
29 minutes ago, TofuHaroto said:
Tried what ?
No I didn’t, removed the cpu from its socket. Cleaned the cpu, some thermal paste around the socket which spilled there the first times I installed it. Put it back in the socket and then attached the heatsink again. Started my pc, no video output, only a red indicator light which is for a problem with the cpu. Re socketed the cpu and then it did nothing.
1 minute ago, Berkan5473 said:
which spilled
Spilled where exactly ?
Build Log:
Just clean it off with some rubbing alcohol and a coffee filter
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i9-10900KF 5.1-5.3ghz @ 1.365v // Corsair iCUE H150i Elite Capellix // Gigabyte Z590 Aorus Elite AX // 32GB (4x8) Crucial Ballistix Elite DDR4 4000/CL18 // ASUS RTX 3080 TUF OC // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Samsung 860 EVO/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B/Lenovo L24Q-30/Lenovo L24Q-30 // Glorious GMMK TKL // Corsair Harpoon Wireless // Corsair H70 Gaming Headset
Wife's System: i9-9900K Stock // Cryorig H7 Quad Lumi // Gigabyte Z390M Gaming // 32GB (4x8) Corsair Vengeance LED DDR4 3200 // ASUS KO RTX 3070 // Cooler Master Master Box NR400 ODD // Seasonic Focus Plus Gold 850w // 1TB ADATA XPG SX8200 Pro/1TB Samsung 860 EVO/4TB Western Digital HDD // Displays: LG Ultragear 27GL83A-B/AOC AGON AG241QX/ASUS VG248QE // Corsair K68 Mechanical Keyboard // Corsair Harpoon Wireless // LG BDRW // NexStar 5.25" USB 3 Enclosure
TV Gamer: i7-8700K 5.0ghz All-core delidded @1.375v // Deepcool Gamerstorm Assassin III // Gigabyte Aorus Z370 Gaming 5 // 32GB (4x8) Corsair Vengeance LPX DDR4 3200 // XFX 5700XT RAW II // Corsair 275R Airflow // Corsair 650M Vengeance 650w // Intel 660P 1TB NVME M.2 SSD/4TB Western Digital Blue // Display: 50" Westinghouse 1080p // Rii Wireless Mini Keyboard w/Touchpad/Xbox One Controllers
TV Gamer 2: Intel i3-10100 // ASRock H410M-HDV/M.2 // 16GB (2x8) DDR4 T-Force Vulcan 2666 // XFX RX 580 8GB XXX Edition // Rosewill FBM-X2 // Gigabyte P750GM // 480GB PNY CS1311 SSD/2TB Seagate HDD // Display: LG 50" 4k TV // Rii Wireless Mini Keyboard w/Touchpad/Xbox One Controllers Donated.
Son's System: i7-8700 // Cryorig H7 Quad Lumi // ASRock Z370 Extreme 4 // 16GB (2x8) GeIL Potenza DDR 3200 // EVGA XC RTX 3060 // Corsair 275R Airflow // EVGA Supernova G5 650W Gold // 525GB Crucial MX300/1TB WD SN550 // Display: ACER Nitro VG240Y PBiip / Dell P2417H // Corsair K60 Pro SE // Logitech G203
Daughter's System: i5-9400 // Cooler Master i71c // MSI H310M Pro VDH-Plus // 8GB (2x4) Leven DDR4 2666 (2400) // Zotac GTX 1060 3GB Mini // DarkFlash Micro ATX White // Corsair CX550 // 480GB PNY CS1311 SSD/2TB Seagate HDD // Display: ASUS VG245H // Redragon TKL Mechanic Keyboard + Mouse
Ryzen 5 1600 // Gigabyte B450 Aorus M Retired.
On the side of the socket but not inside
so one the printed circuitry ?
Build Log:
On the side,  not on the circuitry. But does thermal paste conduct electricity?
thats not the concerning part the concerning part is if you shorted the board by spilling alcohol on the mobo (which is conductive)
Build Log:
It depend on the thermal paste.
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
Didn’t spill it on the motherboard. But I know for sure that there got some on the pins of the procesor so I’m pretty Shure I short circuited my processor, does that have any effect on other components which I will have to replace then?
for the most part not the ram not the gpu and not the storage but you might (and i could be wrong ) you might have shorted the mobo (as i said i could be wrong )
Build Log:
Oké, i guess I’ll save some money in the hope it’s only the processor. Does it matter if I put a working processor in the motherboard?
if you have a spare pga 1331 (am4) cpu try it maybe the mobo isnt dead and it could be just the cpu
Build Log:
I don’t have one, I can return my cpu if it didn’t work out cuz of how ordering is fixed in the eu
Nvm managed to get it working somehow and stress testing it rn
 Share
