Search In
  • More options...
Find results that contain...
Find results in...
Need Help with AMD Ryzen 7 2700
Go to solution Solved by dzankobananko,
I feel so dumb right now for bothering you guys, upon further inspection the 7 2700 does have a 4.1 turbo clock on a single fastest core. With all cores being maxed out at 3.4 without further oc by the user. Its a single core boost clock and core number 3 does get that. Thank you for helping me
Hey i just updated my MOBO bios to the f50, my mobo is the gigabyte b450 gaming X.
After the update my cpu stopped boosting to 4.1 ghz and is stuck at 3.4 when maxing it out with AIDA64, after downgrading to the F41 BIOS again im having the same issue.
Please help me out
Please help me out
Try clearing the cmos and see if xmp / dcop for disabled and re enable it again
Phone: Pixel 3a (Purple-ish).
Build Log:
2 minutes ago, dzankobananko said:
How would i clear the cmos
Before clearing the cmos make sure you have dcop/ xmp enabled
Build Log:
What are thermals like? Both CPU and motherboard thermals. Use HWiNFO 64 to track those. Also are the chipset drivers updated?
The thermals are great i have an AIO cooler its not the stock one. As for the chipset drivers im not sure if they are i just thought windows does that on its own
3 minutes ago, dzankobananko said:
How would i get the chipset driver
From AMD-s website. Those on the motherboards website are heavily outdated, those on the windows store are both outdated and incomplete.
Also, the only proper way to monitor a Ryzen is through Ryzen Master, the official tool.
Im looking at the AMD driver webiste now and it seems it started downloading ryzen master
Install the latest chipset drivers/BIOS/updates - reset the BIOS/windows settings to default and use Ryzen Master for thermal tracking. Also track motherboard thermals - the VRMs on your board are pretty mediocre so it could be the board is overheating.
Installing chipset driver now, the bios is the old one as I went back to try and fix it
Update it - the F41 had a bunch of issues on its own. Use the proper BIOS utility, do NOT update in Windows
chipset didnt solve it let me try doing the BIOS update again, im doing it over q flash
Would I need to reinstall the chipset driver or no
No, do all of the things I listed and THEN test.
When you install the new bios ?
From my understanding no you won't
Build Log:
And did you try clearing the cmos ?
Build Log:
Ok back in a bit
Good luck
Build Log:
Again with AIDA pushing it to 100 precent we dont move from 3.4
Can you monitor your temps
Build Log:
 Share
