Search In
  • More options...
Find results that contain...
Find results in...
Motherboard lights flashing.
Hi, I built my first computer a few days ago and I decided to add a few more fans to the build. At first it was a success only thing is that the rgb didn't work on my fans. So I flipped the connector (see pic.1) which I put into the DLED_V_SW2 header (see pic.2). After that I tried turning the pc on, the CPU fan spun for half a second and then the motherboard and power switch started flashing. Does anyone have an idea of what went wrong?
Motherboard: Gigabyte B450 aorus pro
CPU: Ryzen 5 3600
PSU: CoolerMaster MasterWatt 650W
Edit: forgot the pictures
Edited by Benni77
 Share
