Fractal Design Integra 450W enough for GTX 1070 Ti and Ryzen 5 1600
Solved by Dappner,
Just now, Toffee_Bear said:So given the current situation my GPU arrived but my PSU is severely delayed, I'm just wondering if the included PSU in the node 202 is enough to run a Ryzen 5 1600 and GTX 1070 Ti with no overclocks on either?
I've checked on pcpartpicker for the power estimate which should apparently leave me with a 120W overhead, but apparently it's a 80+ bronze PSU and nvidia recommend a 500W PSU.
I would appreciate any advice.
Thanks
You should be fine, however if this is a build you intend to continually upgrade, I would recommend at least a 550-600 Watt PSU, as it also has better power efficiency.
