B450 Tomahawk Max with 3600MHz?
Solved by Jurrunio,
2 minutes ago, dejans said:
What would you suggest?
3200MHz CL16 or 3600MHz CL17 for the same price.
3600 C17 for sure. At worst you just select 3200MHz and run it at that. The cost is the same anyways
Abdiel72 ·
Posted in Troubleshooting3 -
Goku1814 ·
Posted in Graphics Cards3 -
jetrock888 ·
Posted in LMG Sponsor Discussion3 -
1
2
minato ·
Posted in New Builds and Planning1 -
9
ShadowChaser ·
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
