Please help me with below Best Graphic card with price value
I am thinking 1060 is good but let me know your comments and help me with best build.
I will be pairing it with Ryzen 5 3500 (6core/6 threads ) ₹10,000  (132.55 USD ), MSI A320 Pro Max mother board
Galax GTX 1650 Super EX (1-Click OC) 4GB   ₹14,299   (189 USD )
Inno3d GTX 1660 Twin X2 6GB   ₹16,275    (215 USD )
ASUS RADEON RX 580 4GB OC DUAL EDITION GDDR5    ₹11,900   (157 USD )
SAPPHIRE PULSE RADEON RX 580 8GB GDDR5     ₹14,499    (192.19 USD )
INNO3D GEFORCE GTX 1060 6GB DDR5 GAMING OC GRAPHICS CARD    ₹12,999   (172.31 USD )
id suggest not buying the 1650 as it has a really bad pricing and the RX 580 is usually better in all games
the RX 580 is a good bit faster frames than the 1060 providing 6%more frames at 1080p
Atm get a rx580 or 590. the 590 can catch the 1070 is some games .
On the used market look for a Vega 56 or 64 for cheap.
Nvidia cards for the same performance normaly are more money even on the used market
First of all
I assume you don't have the parts yet so let me change a couple of things
1st change your a320 board to a b450,
The chances of your a320 board supporting zen 2 is very unlikely
2nd for th GPU just get the 580 it has the biggest memory buffer out of all of the three cards and is the cheapest and is relatively close to a 1660
Phone: Pixel 3a (Purple-ish).
Build Log:
580 8 GB.
most VRAM, cheaper than the 1660 but is close in performance.
stuff is cool. stuff that has fancy lighting is cooler. stuff that has fancy lighting and works is the coolest.
i game so i know a bit abt gaming tech, not much abt professional tech.
writing this as i finish a 3 hour D2 sesh so excuse anything wrong.
Thanks for the Quick reply ,
1st change your A320 board to a b450  ---   yes I wanna save money to spend more on GPU and I won't be changing CPU once i bought them for a Long time.
For RX 580 GPU as per Youtube benchmarks on Games 1060 have more FPS, which made me confused.
RX 590 cost me around RS 16,999  (225 USD )
which is bit costlier than is it that needed ?
Idk how old the video your watched but a 580 is definitely faster than a 1060
And upgrade your a320 if you want to boot, lol
Most a320 boards don't support zen 2 (3rd gen ryzen ) so you most likely will have to go to b450
Build Log:
Surprisingly it does have  Turbo M.2, USB 3.2 Gen1
Execpt Over clocking i will get everything , I will tweak a little bit for that too and moreover not an over clocker
You can't over clock with a320
Build Log:
Just now, Bharghav Shyam said:
I Can atleast  get 4.1 GHZ on CPU and stock on GPU
No you can't over clock at all
Build Log:
12 minutes ago, Bharghav Shyam said:
Yup i can Over clock too my base 4.1 Ghz
Your cpu is rated at that
That's no an of profile
It's just the cpu it self
Build Log:
