Search In
  • More options...
Find results that contain...
Find results in...
Recommended tv to use as pc monitor.
josh912
 Share
I use my tv as my monitor for my pc and currently have a 55" tv. I just built a new pc and wanted to upgrade my current tv that I purchased in 2013. I have a budget of 1000 usd. I would like to get 120hz but at that price i understand I am asking for champagne on a beer budget. What would you recommend I purchase? Thanks for the input!
Why does it have to be a TV? For 1k$ you can get a realy good Monitor. TV´s in that range arent comparable.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
Only BFGDs and some high end LG displays support 120Hz.
Also, no GPUs with HDMI 2.0 exist so you either need to get a BFGD with dispalyport ($5000+) or change your resolution to 1440p every time you want to game.
Go to rtings.com and look at the TV reviews to find one with low input lag.
Cause gaming on a 55"+ screen is far more fun and immersive than a tiny 24 or 30" monitor...
If you enjoy a giant screen, why not go for a 49” ultrawide? They can be found for a lot less than 1k and are meant for gaming.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
27" or ultrawide is all you need if you sit infront of it. + Gsync ect. No TV can deliver that.
I use it in my living room and sit a fair distance away so I need it to be larger.
49" ultrawide is just a 55 or 60" tv with the top and bottom chopped off.
When you want to watch anything that's 16:9 (like 99% of all content) you end up with a tiny picture size with black bars on the left and right.
It's much better to use a larger screen and get more vertical realestate, and you can still do ultrawide for gaming if you want.
LOL clearly you've never used a TV as a monitor...
I've been on 55"+ for the past ten years, no monitor config even comes close to being this immersive.
Maybe if you had a projector, or those movie theaters that let you book a room and play games are more imemrsive.
Ok. So not on a Desk. My TV is far away too. its 65" and around 4m away. But i dont Game on it.
That is correct, I should have specified sorry.
LG has an OLED TV with Gsync. But i doubt 1k will cut it.
Yeah I have seen that one and its 1900.00 at 65" but only 1300.00 for the 55" and it's a really good tv. Linus actually did a video on it and I think still has it set up in his house. I may end up spending a bit more for that tv.
Lg c9 55 inch (should be around 1400 range) 120hz, G-sync + Hdmi 2.1 for future. There is a CX (C10) release coming with new monitors (minor updates, but still) including 49inch which might be attractive for you :) Read about OLED burn-ins, if that scares you, I can recommend samsung QLEDS, Q70R up. Not as good picture as OLED, but damn pretty and close :)
LG B9 55" is $1300. If you can stretch your budget a bit, that would be by far the best choice.
If not, the Samsung Q70T 55" can do 1440p @ 120hz (4k only @ 60hz). What sort of graphics card will you be hooking the TV up to?
https://www.bestbuy.com/site/samsung-55-class-qled-q70-series-4k-uhd-tv-smart-led-with-hdr/6402398.p?skuId=6402398
https://www.rtings.com/tv/reviews/samsung/q70t-qled
CPU: Ryzen 7 3700x || GPU: RTX 3080 Founders Edition || Memory: 48GB Corsair 3000mhz DDR4 (22GB PrimoCache) || Motherboard: MSI B450 Tomahawk || SSD1: 500 GB Samsung 850 EVO M.2 (OS drive) || SSD2: 500 GB Samsung 860 EVO SATA (Cache Drive via PrimoCache) || Spinning Disks: 3 x 4TB Western Digital Blue HDD (RAID 0) || Monitor: LG CX 55" OLED TV || Sound: Schiit Stack (Modi 2/Magni 3) - Sennheiser HD 598, HiFiMan HE 400i || Keyboard: Logitech G810 || Mouse: Logitech G502 || PSU: EVGA 750-watt Gold
I was leaning towards the Samsung Q70T as well but I will take a look at that LG thanks. I will be running a Sapphire Radeon RX 5700 XT
Lean towards the Samsung, then. Samsung's current LCD lineup supports Freesync. LG's B9 does not. You will have a better experience if you go with one of the Samsung models.
Hey so Im planning on building a $1k system with a 2060 KO Ultra and I own a q70r. Do you think it would be worth it to switch to a rx5600 xt just for Freesync even though the RTX has more feature that I want. I've never used a VRR TV or monitor so I don't know. Maybe Nvidia will add Freesync support over HDMI?
It's up to you, honestly. I don't know how fast an RX 5600 XT is compared to an RTX 2060 KO (and obviously the RX 5600 XT does not have RT).
If you have never had a freesync/gsync monitor, then it you won't know what you're missing. If you have and are used to tear-free gaming, then trust me on this... you're going to hate going back.
 Share
