Search In
  • More options...
Find results that contain...
Find results in...
PROBLEMS AFTER REINSTALLING WIN 7 (On a Laptop )
Hallo guys,
after I reinstalled win 7 in my Samsung laptop lots of problems appeared.
The wlan doesn’t work and I can’t get it fix and the lan port doesn’t work to.
so I can’t download any drivers what so ever.
If there is any possibility to run the WiFi again pls help me.
sorry for my bad english and thanks :)
I assume that you have a USB stick since you were able to re-install windows 7. Now, just go on some other pc you have and try to download the drivers from there then transfer them to the usb stick then install them to your laptop from the usb stick.
Ahh Great!!
But since this Is a laptop ... how should I know what driver I need for my wlan ???
13 minutes ago, Kjell.hel said:
Ahh Great!!
You go to the samsun support website. Look for the model number of the laptop and download the driver from the website.
 Share
