Search In
  • More options...
Find results that contain...
Find results in...
Single slot, preferable passive cooled cards required
 Share
Can anyone suggest what cards may be suitable to jam up against each other? Not looking for blazing performance, but enough to run a 1080 desktop and media playback.
Need to be cheap as this is only an experimental machine, and as some may end up mounted externally with cables and PCIe splitters, it could be a giant failure.
look into nvidia quatro cards,  old amd workstation video cards...
ex nvidia nvs 300, 310 and nvs 450 and similar (these may not have windows 10 drivers), quadro 600, k600 (these are newer and should have windows 10 drivers but double check)
amd ... firepro 2270, v3800, v3900, v4900, v5700 (same story about potentially not having windows 10 drivers, check)
amd hd 6350 , hd 6450 and models in the series are super cheap, lots of oem dell cards like this for a few dollars each... also check if there's drivers for windows 10... they'll work otherwise with built in windows driver
amd r5 240, r5 230, r7 250 etc
 Share
