Search In
  • More options...
Find results that contain...
Find results in...
ryzen 4800h/4900h 17in with rtx 2060
Hello,
My wife really wants a gaming laptop. She wants something that will last in terms of reasonable longevity in games, but she also wants a 17 in.
The configuration we want is a 17in, with either a 4800h or 4900h, and an RTX 2060 GPU.
I have struggled to find this exact configuration in 17in. The closest we can come to is a configuration from any vendor is one that uses 1660ti mobile instead. However we really would want rtx 2060...
Is there any model I'm not aware of, or do any of these vendors allow for custom configurations? It appears these days customization are a lot harder then they use to be, and every vendor wants to flash some cinematic crappy looking interface in your face instead of real data.
The only laptops I can find with those specs are 15 inches. If you can wait a little bit, laptops with those specs should be out soon. However if you can’t and need 17 inches then go for the 1660ti or Intel 10th gen (I don’t believe Ryzen has too big a performance jump in gaming)
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
 Share
Newegg
