ryzen 5 3600 thermal issues
flaminfury101
i had bought a ryzen 5 3600 but just after a month at 4.2 GHz with the wraith stealth it reaches 90 within two hours it is usual??
when idle??????????????
no its not usual
No, the stealth is not meant for overclocking, it's for stock use. Remove your overclock, reset CMOS, update the BIOS and chipset drivers and use it stock.
Or a third party cooler like the Dark Rock Pro 4 or the Noctua NH-D15 or if don't have space for massive cooler the Noctua U12A could help bring the temperatures down.
Current computers:
Primary Computer (In Progress):
SUBJECT TO CHANGE
CASE: ROSEWIL THOR V2 Black
CPU:
Motherboard:
GPU: SAPPHIRE VEGA 56 -TBU RTX 2070 SUPER
RAM: 48 GB CORSAIR VENGEANCE LPX
PSU: SEASONIC PRIME 1300 W GOLD
STORAGE: 4x SEAGATE EXOS 4TB | Sans Digital HDD 5-Bay Rack | Sisun IDE SATA HDD Docking Station
SOUND SYSTEM: Logitech Z506 Surround Sound via Vantec USB External 7.1 Channel Audio Adapter
MOUSE: 16000DPI GAMING MOUSE
KEYBOARD: -PENDING-
MONITOR: -PENDING- AOC AGON AG241QX 24" -PENDING-
COOLING:  CPU: Noctua NH-D15 -3x NF-F12 Fan MOD || 10-12X NF-F12 || EXHAUST: 3x NA-A12x25
LAST UPDATED 4/29/20
Secondary Computer:
CPU: AMD FX-8370 Black Edition
Motherboard: ASUS M5A97 R2.0
GPU: Zotac GeForce GTX 970 AMP! Omega Core Edition
RAM: 24GB Kingston HyperX Savage 1600MHz DDR3
PSU: Antec High Current Gamer HCG-900W
STORAGE: 5x Western Digital Black 2TB - WD2003FZEX | Sans Digital HDD 5-Bay Rack | Sisun IDE SATA HDD Docking Station
MOUSE: PUREX 2400 DPI Wired Laser Gaming Mouse
KEYBOARD: DBPOWER 104 Key -3 Backlit -I KNOW! Linus doesn't approve -I have glued it to the desk and it works well for my needs.
MONITOR: ASUS VS247H-P 24 Inch
COOLING: CPU: Noctua NH-D14 -3x NF-F12 Fan MOD || 10-12X NF-F12 || EXHAUST: 3x NA-A12x25
GRAPHICS: 2x NF12s fans on graphics card + 2x NF-F12s & 1x NA-A12x25 in Fan box | 1x Vantec SP-FC70-BL Spectrum System Fan Cards
-> Moved to Air Cooling
Yes and no. If you leave everything at stock, you will see about 80C temps under load. Thats normal for all stock settings (see all other threads just here). You can see the reasoning here:
However, overclocking with stock cooler is not usually recommended, and doing it wrong even less. By this I mean that you are probably running with very high voltages, and cooler just can't dissipate heat as fast as needed.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
No, but have temps gotten significantly worse with time?
