I think my laptop is thermal throttling
Go to solution Solved by King_Arthur,
2 hours ago, StyvyStiefel said:
I believe my laptop is thermal throttling as whenever I play a video, or open half a tab of google chrome, the fan speeds ramp up to 'take off' speeds.
The laptop is a Dell Inspiron 735 2 with an intel i7-5500u. I attached a screenshot of the min and max temps from within the hour.
The laptop is about 5 years old I believe and I think the thermal paste has worn out. To replace it, I ordered a graphite thermal pad to replace it:
[https://smile.amazon.com/gp/product/B07CKVW18G/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1]
What other issues might be causing the cpu to overheat that others have experienced?
I don't recommend a graphite thermal pad because they can't shape themselfs into an even layer and you could get a partial coverage thermal grizzly kryonaut or arctic mx-4 are the best you can put in the laptop and they can last for a long period.
another reason could be a malware or a virus
@StyvyStiefel Well you can just give the laptop a good dust off maybe and clean the fan and so on.
CPU: i5 4670k @4.1ghz | GPU: Gigabyte Geforce GTX 1060 G1 Gaming 6GB | MB: Gigabyte Z97P-D3H | RAM: 4x4GB Generic | SSD: Gigabyte 240GB
PSU: Antec High Current Gamer 650 watt | Case: Cougar MX330G
I much prefer the numbers from HWiNFO64, but the throttle temp for your CPU should be 105C, not 100. Regardless, what's the airflow like? You're using it on a hard flat surface? The fans aren't clogged, etc?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Do you know if the cpu currently has thermal pads or paste on it? Correct me if I’m wrong, but shouldn’t you replace paste with paste and pads with pads.
As for anything else you could do, definitely take the time to clean up the system and make sure all the dust is cleared. When I recently cleaned up a decade old laptop, I put on some cheap Corsair thermal paste from amazon and got dust out wherever I saw it (even opened up the fan casing to get better access). That laptop now works better than ever.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
@KENBAL420To clean it, I removed the back plate and used compressed air with a vacuum hose so it should be clean enough.
@Statik Laptop is always on a flat surface, and as of recently, put on two posts to ensure there's plenty of space below the laptop.
@zeusthemoose I believe what you're think of is thermal pads used for chips on graphic cards :) What I'm talking about is a graphite thermal pad intended for placement on a cpu in replace of thermal paste.
@King_Arthur My liege, I was considering artic for a thermal compound, but I wanted this to be a one time placement and then be there for the end of time. For antiware, I'm running malware bytes and I run scans once a week.
I replaced the paste with the pad and now my temps are better, for anyone wondering. When I removed the heating pipes to the cpu, the paste was in fact dry!
EDIT* Just to be clear, King Arthur's solution would yield better temperatures, but I wanted this to be a place and forget forever situation.
