Search In
  • More options...
Find results that contain...
Find results in...
Folding@Home Ryzen 3800X temps
I'm currently running Folding@Home and my Ryzen 3800X is hitting a peak temp of around 85C on Full Power. Is this too high for this? I'm running with a Noctua NH-D15.
nope your in the clear. (100C is too hot)
NOTE: I AM NEVER ALWAYS RIGHT, BUT I AM HAPPY TO HELP ANYWAY I CAN
Tag me @WambleCropped or quote me so I can see your reply
My Rig: RTX 2060, R7 1700X, Samsung 860 500GB, Masterlite Liquid Cooler, Asrock Pro B540,16GB of RAM G.Skill 2133
PSU Tier List                    SSD Tier List                              Graphics Tier List
You have 10c before throttle temp (95c). You're good.
- If it ain't broken, don't fix it! - - Your post codes and beep codes in the drop down below -
Competitive Benching Team - Warp9-Systems
Save the old OC forums just by reading old school tec
https://forums.extremeoverclocking.com/index.php
They have the best F@H stats too.
85c is a little toasty but folding is VERY intensive (heck my kaby lake i7 can't do it ) so it's normal but just to make sure you can try playing games and record your temps
Phone: Pixel 3a (Purple-ish).
Build Log:
Yeah this is the only thing that pushes the temps past around 75C. Thanks!
Yeah your golden man. My 3800x runs warm too. They're toasty chips.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Then it's perfectly fine :D
Build Log:
 Share
Newegg
