WE WILL WE WILL ROCK YOU
Bloudy_Parrot
HEEEYYY you audiofiles out there i NEED your master-level opinion about this :
 Armaggeddon Pro 7.1 Nuke 11
do you have anything better for under 30$ ??
i repuire a POSSIBLE mic
and i will use it for GTA and music ....... WE WILL WE WILL ROCK YOU......... only me .... ok.
3 minutes ago, Senzelian said:
Never even heard of that brand.
But it says Pro on it and has tons of RGB. Must be good. 😄
this one ????
Motospeed G750
Just now, Senzelian said:
Nope. Never heard of that either. 😅
for under $30 just get anything. They are all going to be bad. but get something without RGB. those probably spent more on the drivers rather than rgb (so you get better sound - hopefully).
hey can i ask you smthing ??
does it matter if your ears get hot during whearing your headphones ??
i whant people's opinion about it for an idea i have....
No, do not put a fan in headphones, bad idea
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
but....🥺
ah yeah...the vibration...................whait how did you know???
ahmmmmmmmmm
M
m
m
m
m
m
m
m
m
m
mmmmmmMAYBE WATER COOL THEM ????????😃😃🙃
i am reteraly gonna water cool my old headphones tomorow and i am pretty sure that my mum wont like it......
8 minutes ago, Saksham said:
for under €27.34 just get anything. They are all going to be bad. but get something without RGB. those probably spent more on the drivers rather than rgb (so you get better sound - hopefully).
 how are you so sure ????
Trust me, she could have it worse, I watercooled a rack mounted dual xeon server with a pond pump, vinyl tubing and $8 ebay blocks.
This was before they did anything like that on the channel too so I went in blind, having built two computers out of bad used parts before......
@rice guru
2 minutes ago, The Flying Sloth said:
Trust me, she could have it worse, I watercooled a rack mounted dual xeon server with a pond pump, vinyl tubing and €7.29 ebay blocks.
pleaeaeaeaeaeaese 🥰
Well, everything costs money on a product.
For them to add RGB, then they would need to spend less money in other areas, such as the drivers.
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
