Cheap gaming pc parts list
Budget (including currency): 100$ CAD (Canadian dollars)
Country: Alberta
Games, programs or workloads that it will be used for: Fortnite, Minecraft, Fallout4, Source Film Maker, Team Fortress 2, half life 2, Portal
I am looking to make a gaming pc of my own and I only have  about 100$ and I'm looking for a list of cheap parts I can get from Amazon and some other online stores.
9 minutes ago, Kaleb Janzen said:
*snip*
bro save up, the minium for a gaming pc is about 400, unless you get very very lucky on ebay
Edited by wkdpaul
NOTE: I AM NEVER ALWAYS RIGHT, BUT I AM HAPPY TO HELP ANYWAY I CAN
Tag me @WambleCropped or quote me so I can see your reply
My Rig: RTX 2060, R7 1700X, Samsung 860 500GB, Masterlite Liquid Cooler, Asrock Pro B540,16GB of RAM G.Skill 2133
PSU Tier List                    SSD Tier List                              Graphics Tier List
Nope. Have look at second hand market for that price range. 100 dollars probably can just second hand/business/government ex dell prebuilt like 2nd i3 ... which is not something you want waste. Save up more.
Magical Pineapples
You might be able to find a machine with an i5 2000 or better yet an i7 2000 series for close to that much
then you just need a 1650, or a used RX 470-580 if the PSU is decent.
*snip*
Have you browsed the used market, as well as YouTube to know what to buy?  $100 CAD cannot get you a gaming machine with what you'd need to play those games + Peripherals.
Save up another $100-$150 CAD and then you're talking some used finds.
Edited by wkdpaul
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
I have an old Windows xp Dell but when I power it on it beeps 3 times and doesn't work
May we see the specs, or perhaps the model? Hopefully you can salvage something from that PC. You might also want to look on Amazon for used Dell Optiplex models, I have seen some great prices for computers that have a core i5 in them, which is great for the budget gaming space. They also fit a standard ATX power supply, which means that you can get some good value out of them when it's time to upgrade.
Trash beauty:
CPU: Xeon X5550
GPU: RX 570 4GB (defective)
SSD: Fattydove Racing 240GB
HDD: WD Blue 320GB
Motherboard: HP Z400
Ram: 6x2GB DDR3 1066
PSU: Corsair TX650
Probably just try installing some flavor of linux on it to get it up and running
1 long beep, 3 short beeps?
2 minutes ago, Kaleb Janzen said:
3 short beeps and I'll have to check the specs of it
might be a ram issue, you can try replacing it and see what happens.
I can't see the exact specs because it won't work right but it's a Windows Xp professional. Dell OPTIPLEX 745. Also it has Intel Pentium D
I have messed around. With the ram now the beeping stops but it won't display anything and my keyboard and mouse don't turn on
you can get a Q6600 and 4 sticks of 2gb DDR2 ram, shouldn't cost that much now that the platform is worth nothing.
I checked the Q6600 is over 90$ to get a used one and for new about 200$
the ram is 30$ for 1 stick of 2gb ddr2 ram
where exactly are you getting those prices? ebay and aliexpress have the Q6600 for $7.
Newegg and amazon
Also I have an old IBM Windows 98 that should still work
But I havnt  used my 98 for a few years since I got my xp
I am currently using a laptop Acer Aspire ES15 with 4th of ddr3 L memory and Intel Hd graphics 500
Intel Celeron processor N3350
12 hours ago, Kaleb Janzen said:
Newegg and amazon
Always buy used for old hardware. Amazon and Newegg unfortunately have no good used options for those CPUs.
Like mentioned earlier, a refurbished Dell Optiplex with an i5 is what you want.
Primary PC:
