Search In
  • More options...
Find results that contain...
Find results in...
Please help
Gamerfiend_
 Share
Go to solution Solved by jjbeebe,
This is caused when something is edited that should not be; for example if you are using something like cheat engine to edit values this could cause this error. Other issues include driver, overclocking, malware and several more. Please provide more information on any relevant modifications.
I have been getting my PC crash multiple times when doing certain things, firstly I noticed it would blue screen when using Shadowplay to record Forza Horizon 4 and it's just done it again for like the 5th time on f1 2019 whilst streaming, I keep getting the "critical process died" BSOD , Any ideas?
Phone: Samsung Note 10+ 5G | Computer; CPU: AMD Ryzen 9 3900X | Mobo: Gigabyte Aorus Elite X570 | RAM: 32GB Corsair Vengeance RGB DDR4 | GPU: MSI Gaming X TRIO RTX 2070 SuperCase: NZXT H440 (Razer Edition) | OS: Win 10 | Storage: 1TB Intel M.2 SSD (OS), 2TB Seagate Firecuda, 128Gb Crucial SSD, 1TB WD Blue | PSU: Corsair RM850 | Display: LG 1440p 144HZ 31.5" Cooling: Corsair H115i Platinum RGB | Keyboard: Razer Blackwidow Chroma | Mouse: Razer Lancehead Wireless | Audio: Blue Yeti | Cam(s): Logitech C922
 Share
