Wireless network card not working in new PC build
Pixelest
Hey guys so I just built a new computer. Everything is working fine besides my network card. I have updated the drivers and the computer recognizes it. I can see available networks when i open the networking tool in the task bar. when I select my network it just says cannot connect to network. I have had it connect actually maybe twice but for the majority it doesn't work. I have a little usb adapter and that seems to work fine. Hard line lan into the mobo works fine as well I just built the computer and everything works fine besides this. The hard ware and software I have is as follows.
Network card in question is
(Rosewill rnx-ac1900pcev2)
OS
Windows 10 pro x64
Other Hardeare
MSI Pro z390-A Pro
Intel Core i5-9600k
G.Skill Ripjaws V series 2x 8gb
Geforece RTX 2070 Super
27 minutes ago, AeroMagnus said:
Have you downloaded drivers for it?
Yes I have the latest drivers from thier website
I think he means your motherboard website.
Look for the exact motherboard and install the drivers. I had similar problems before and that usually fix it. Remember to restart the pc after installing the drivers from the motherboard website.
Also, be sure that the wifi card is not DOA.
