Search In
  • More options...
Find results that contain...
Find results in...
Black and white DDC pump tops
Hi everyone!
So I'm planning a build around a Thermaltake S300 Tempered Glass Snow Edition:
https://www.newegg.ca/thermaltake-tt-premium-s300-tg-snow-atx-micro-atx-mid-tower/p/N82E16811133425?Item=N82E16811133425&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-
It was only $120 CDN, (plus a bleeping $50 for shipping!). The case looks great on line, however, I have to wait until next Monday for delivery. :( I also managed to snag a XSPC TX360 Ultra Thin Radiator as an "open box" bid on eBay for $45 USD:
http://www.xs-pc.com/radiators-tx-series/tx360-ultrathin-radiator-white
I'm currently planning a 2 pump build with Laing DDC's. I already have a XSPC black acetal top for one of the pumps and I would like to find a white top for the other pump, (currently it has a clear acrylic top).
Does anyone have any recommendations for a white pump top? Also, can anyone recommend black and white cooling fluid?
Thanks!
zog
2 hours ago, zogthegreat said:
-SNIP-
Swiftech makes both a black and white versions of the DDC pump tops:
http://www.swiftech.com/mcp35xhousing.aspx
As for fluid if you want black or white it will need to be an opaque or pastel fluid. Options from Mayhems and EKWB's Pastel lines are both good options.
Thanks @W-L
(EDIT Do you think that I should go with the Mayhems Pastel Ice White or the Mayhems Pastel White / UV Blue? I'm not planning on running UV lights, but I know that blue is added to white to make it appear more "brilliantly" white, (sorry, college art classes coming back! ;))
1 hour ago, zogthegreat said:
Thanks @W-L
I don't believe the UV additive they use has any kind coloring to it, as they have the same UV Blue option in their clear Mayhems X1 series of fluids.
Also as an option if you are planning a dual pump loop swiftech has a dual dump top design for the DDC series in black or white to match your build:
http://www.swiftech.com/MCP35X2housing.aspx
Edited by W-L
 Share
