Search In
  • More options...
Find results that contain...
Find results in...
GTX 1660 Ti and AMD FX-8320 Eight core, Am I bottlenecking my system?
Go to solution Solved by Tristerin,
9 minutes ago, AK-Preacher said:
What CPU would you say is appropriate to set me at the level of my GPU? and does my RAM need to be doubled to keep up as well?
On your current platform I would leave it as is - even overclocking my FX to 4.6-4.7ghz wasn't worth the heat it created for minimal gains at best.
Greetings,
I've recently built a PC with some of my older components
GPU :GTX 1660 Ti
CPU: AMD FX-8320 Eight Core 3.5 GHz
Ram: 2 X 4 GB DDR 3
SSD: 256 GB
Are my Ram sticks and CPU holding back my GPU ? I've been told that my CPU still holds up til this day even though I've had it since 2014.
I've looked into this a lot and I couldn't find anyone with a similar system configuration.
Thank you.
Yes, it looks like it will be bottlenecked, according to this video.
it depends entirely on the games and performance target. are you getting the performance you want?
Primary PC:
i7 8086k (won) - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G2 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me.
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - dark mode Ubuntu (and Win7, cuz why not)
How many watts do I need? Seasonic Focus threadUserbenchmark (Et al.) is trash explained, PSU misconceptions, protections explainedgroup reg is bad
Not quite, I get drops on CPU intensive games like Vermintide 2, but same time Total War Warhammer 2 runs fine with occasional dips.
3 minutes ago, JoostinOnline said:
This is going to bottleneck just about anything.
Which AMD CPU do you recommend that wouldn't be going beyond my current GPU?
I can only give similar personal experience - my FX 8350 bottlenecked the everliving F out of my R9 Fury which is roughly 20% slower than your GPU.  While this will depend on the type of game and how taxing it is on the CPU etc etc
Current in process build: Project Odyssey - Build Logs - Linus Tech Tips
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Ryzen Rig 3: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler in push/pull, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.  Lenovo 27" 1080p 60hz placeholder monitor, generic mouse, generic keyboard.  Still a work in progress
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Ryzen Rig 2: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) 3600mhz V-Color Skywalker (or 4x8gb DDR4 2666mhz for large tasks), Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.  Zalman K600S keyboard, Zalman ZM-GM1 mouse, Viotek GN24C 24" 1080p 144hz curved and Hannspree HF207 as 2nd monitor
https://www.3dmark.com/3dm/37004594?
Ryzen Rig 1: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire R9 Fury Tri-X Nitro 4gb HBM, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case.  Zalman K600S keyboard, Zalman ZM-GM1 mouse, Acer XF270HU 2560x1440 144hz IPS monitor
https://www.3dmark.com/3dm/37628874?
Dell OptiPlex 3040 MFF: Dell 0MGK50 A02, i3-6100T, 2x4gb DDR3 1600, Team Group 120gb SSD, 500gb Seagate 7mm HDD attached storage, Windows 10 Pro, Logitech K400+, USB Wifi adapter all vesa mounted to the back of a 37" 1080p TV
Linux Box: Toshiba Laptop, i7 620M, NVS graphics, 4gb ram tinker toy at the moment.  Running Manjaro XFCE at the moment.
Home Security: ZOSI 8 channel CCTV (4 used at this time, 1080p) DVR H.265+, 3tb HGST Enterprise HDD, ASUS monitor for display
On your current platform it wont matter much, not enough gains vs the cost of this old equipment.
A full platform upgrade will be suggested to eek out the performance of your GPU.
But if it works for your situation, don't worry about it
if you get good performance you shouldn't really worry about a bottleneck.
Primary PC:
Thank you all for your responses.
I will keep my build as is for few more months before i decide to upgrade it again.
 Share
