Volume button on Task Bar shows only Volume Mixer but I can't switch audio devices
Alright alright, I fixed it.
I reverse engineered every possible change I could've done to me and my gf's computer and found a nice value that on a simple search on the web brought me to a nice regedit trick
To anyone who's battling this too, here's the solution:
Go into the regedit
Find this:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion
Inside there, there should be a folder called MTCUVC
If your issue is like mine, the value should read out EnableMtcUvc = 0
It should be EnableMtcUvc = 1 (Click on it twice to change the decimal)
This is also a method to bring back the old volume slider from old Windows versions, set the value to 0 if you don't want the modern look, or set it to 1 to set it back to the modern look.
