Did i Burn My PNY GTX 1080ti oc 11g?!! HELP :(
Solved by xraijin,
Hello Again,
I'm here to To answer my own Question,
it Truned that the mod that i did to the 6pin with a 6pin+2 was Clean and correct!
and the GPU Didnt burn out it still fine!.
The red Screen turned to be a HDMI Cable Problem!
so when i changed my HDMI Cable the GPU worked just fine still it wont do any heavy work since my PSU is very low
so i bought a new PSU 750W with 2x PCI 6pin+2 and everything is fine and nothing got dmged from the 1st test!
in the end i would like to Thank you for your replays.
