Search In
  • More options...
Find results that contain...
Find results in...
CPU Temps at 60 degrees while folding at heavy normal?
Ok so I am using Ryzen 5 3600 with an rtx 2060 super (gigabyte wind force OC 2x) so for I am using a total of 9 cpu threads (out of my ryzen 5 12 threads) Is it normal this type of usage?
yes thats well within acceptable temps.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w | VDU: Panasonic 42" Plasma |
GPU: Gigabyte 1080ti Gaming OC w/OC & Barrow Block | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + Samsung 850 Evo 256GB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P |
Sidenote: you probably either want 8 or 10 cores because splitting across an SMT pair doesn't really decrease utilization by much.
Main System (Byarlant): Ryzen 5 1600X | Asus B350-F Strix | Corsair H80i V2 | 16GB G.Skill DDR4 3200MHz CAS-14 | XFX RX 5600 XT THICC II | Samsung 960 PRO 512GB / Samsung 970 EVO 500GB / Crucial MX500 2TB / Seagate 7200RPM 3TB / WD White 7200RPM 8TB | Corsair CX650M | Mellanox ConnectX-3 10G NIC | Anidees AI-07BW Case | Dell U3415W Monitor | Microsoft Modern Keyboard
TrueNAS Server (Veda): Core i3-4170 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 4x 10TB WD Whites / 2x 1TB HGST 2.5" / 1x Samsung PM961 128GB SSD / 1x Kingston 16GB SSD | Seasonic Prime Fanless 500W | Mellanox ConnectX-3 10G NIC | LSI 9207-8i LBA | Fractal Design Node 804 Case (side panels swapped to show off drives)
Media Center/Video Capture (Jesta): Core i7-2600 | Asus H77M-PRO | Stock Cooler | 8GB No-name DDR3 | EVGA GTX750Ti SC | Sandisk UltraII SSD 64GB / Seagate 1.5TB HDD | Corsair CX450M | Hauppauge ImpactVCB-PCIe | Syba USB3.1 Gen 2 Card | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | (all-around awesome machine)
Laptop (Rozen-ZuluSony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Kingston 120GB SSD | Blu-ray Drive | (lived a good life, retired with honor)
Tablet (---): Samsung Galaxy Tab A 8" (crosses fingers)
Tablet (ReGZ)Asus T102HA (BIOS clock doesn't tick, loses time when sleep/off) (I kill tablets with disturbing regularity)
Tablet (Unicorn)Surface Pro 2 (battery will reset total capacity to current charge, leading Windows to think it's always 100% charged until it dies)
Tablet (Loto)Dell Venue 8 Pro (screen discoloration issues, wouldn't update to Windows 10)
Tablet: iPad 2 16GB (WiFi died, basically useless after that)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M (?) | HooToo USB 3.0 PCIe Card | NZXT H230 Case
Camera: Sony ɑ7II (w/ Meike Grip) | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance SDXC cards
my cpu has a m ax 6 physical cores, un less you mean the 12 logical cores ?
Sorry, yes "threads" not "cores".
Listen to what I mean, not what I say. ;)
so 8 to 10 thread on one work unit?
I can't speak to how F@H (the program) handles thread scheduling, but when I had it running, I assign process affinity in Task Manager to keep it off Core 0 and 1 so my computer is still usable.
That said, I would assume Windows and/or the program would prefer an even number of threads.
That said, I would assume Windows and/or the program would prefer and even number of threads.
whats process affinity?
This.
5 minutes ago, AbydosOne said:
This.
thanks bro. oddly enough i saw my max temps went down from 72 to 60 lol
 Share
