Search In
  • More options...
Find results that contain...
Find results in...
Can a three pin fan run on two pins?
bacithecat
 Share
I received a fan splitter cable that had one 4 pin connector and the other two had 2 pins then no pin then 1 pin. Is this a defective cable or can i just have my three pin fan run on two pins?
Yes, a 3 pin fan can run on a 2 pin connector.
Your fan splitter probably has a couple 'tails', only one of which has the third pin available.
The third pin on a fan header is 'sense', basically it's able to see how fast a fan is spinning. Of course it can't ask three fans at the same time how fast they are running; so only one tail of the splitter has this third pin.
this is what it looks like. Do u still think it would run?
Yes, a 3 pin will fan will run in either of those  connectors.
The third pin is sense, so only needed on one of the fans on the splitter; not all.
Because of the plastic 'guard' on the fan connector and header, you can only plug in the fan one way.
thanks!
 Share
