How to overclock a monitor?
bacithecat
Im getting a 75 hz display and want to overclock it so i dont tear at like 90 fps. is this even possible?
7 minutes ago, NZgamer said:
Yes. What GPU do you have?
gigabyte 1660 super
2 minutes ago, huilun02 said:
So you want to avoid screen tearing
Have you confirmed that as of now, frame capping at 75fps results in no tearing?
Otherwise you will still get tearing with the display overclocked to 90Hz
Regardless of the graphics card you are using, you can use CRU (Custom Resolution Utility) to do the overclock with a custom resolution
With Nvidia cards you can set a custom resolution in Nvidia control panel without any additional software.
You will have to search the internets for the custom resolution settings that might work with your display model/resolution.
Good luck
i havent verified the frame capping. just know the monitor is. 75 hz display. i have a nvidia card so will check out the control panel. whats a custom resolution?
9 minutes ago, NZgamer said:
What you need to do is open the Nvidia Control Panel (I have an AMD card, so I apologise if I make a mistake) and what you need to do, is find something along the lines of "Custom Resolution". Leave everything except the Hz box as default and enter 90. Click apply. It will not apply the overclock yet, so keep following along. Now open Windows Settings and open System
Now, scroll down in Display options and click Advanced Display Settings
Now, click Display Adapter Settings For Display 1
Now, click monitor
Now, in the dropdown box, select 90Hz and click apply. If your monitor presents with an error, follow my steps again but with a slightly lower overclock.
Hope I could help :)
Thanks!
