Search In
  • More options...
Find results that contain...
Find results in...
Can't control NZXT AER rgb fan's speed.
IIIMARKIII
 Share
Hey guys!
I bought my PC and had it built by the computer store. I have 2 AER rgb fans and a kraken x62 and for some reason in CAM, I can't control the speed of the 2 fans. I can control the rgb and stuff, but not the speed.
I have a hue 2 controller, I don't know what's wrong. Would taking a picture of my mobo help to see if the fan header is plugged in wrong?
In the bios, it sees 1 fan, but can't actually control it.
Hue 2 is only for RGB. Where are the fans connected? (4pin fan connector)
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
If i see correctly only 1 thing is plugged into the motherboard cpu_fan connector.
So where are the others connected to? You would need to buy Grid+ to control fans with CAM. They are probably using some hub now.
 Share
