Posted April 28, 2020 I used a wrong solution on my monitor by accident. Do you think there would be any damage from a one time use? Immediately cleaned it with the right solution afterwards. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 28, 2020 1 minute ago, OGTrey079 said: I used a wrong solution on my monitor by accident. Do you think there would be any damage from a one time use? Immediately cleaned it with the right solution afterwards. Probably not an issue, but you may have damaged some of the coating on the front, but if you don't notice it; there is no harm "We're all in this together, might as well be friends" Tom, Toonami. mini eLiXiVy: my open source 65% mechanical PCB, a build log, PCB anatomy and discussing open source licenses: https://linustechtips.com/topic/1366493-elixivy-a-65-mechanical-keyboard-build-log-pcb-anatomy-and-how-i-open-sourced-this-project/ mini_cardboard: a 4% keyboard build log and how keyboards work: https://linustechtips.com/topic/1328547-mini_cardboard-a-4-keyboard-build-log-and-how-keyboards-work/ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 28, 2020 Author Just now, minibois said: Probably not an issue, but you may have damaged some of the coating on the front, but if you don't notice it; there is no harm .. Would it be immediately noticeable if there was damage? My monitor does have an anti glare coat. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 28, 2020 Just now, OGTrey079 said: .. Would it be immediately noticeable if there was damage? My monitor does have an anti glare coat. If you cleaned it, it's either clean or you see damage. But honestly, if you have not noticed anything; there is nothing to worry about "We're all in this together, might as well be friends" Tom, Toonami. mini eLiXiVy: my open source 65% mechanical PCB, a build log, PCB anatomy and discussing open source licenses: https://linustechtips.com/topic/1366493-elixivy-a-65-mechanical-keyboard-build-log-pcb-anatomy-and-how-i-open-sourced-this-project/ mini_cardboard: a 4% keyboard build log and how keyboards work: https://linustechtips.com/topic/1328547-mini_cardboard-a-4-keyboard-build-log-and-how-keyboards-work/ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 28, 2020 Author Just now, minibois said: If you cleaned it, it's either clean or you see damage. But honestly, if you have not noticed anything; there is nothing to worry about Cool. Thanks for the quick reply! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
