Search In
  • More options...
Find results that contain...
Find results in...
Is it worth getting a 1440p monitor considering my system?
wujoh
 Share
hey all, I'm considering getting a 1440p monitor but I'm not sure if my system can handle it.
Im running a 3600x and a 5600xt ( I don't think the rest of the specs are relevant but i can provide them if necessary). My current monitor is 1080p@144hz and I'm considering either a 1440p@60hz or a 1440p@144hz If i can find a good enough deal. my main concern is that my gpu won't be able to handle 1440p all that well. What do yall think
Hey. Sure you can. Your gpu will run 1440p just fine. 60fps on max settings in heavy titles and it will do 100+fps when going medium or playing more lightweight games
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
You can always lower the resolution in game if the GPU isn't powerful enough to do 144 Hz at that resolution. It's definitely worth it for desktop stuff, if you do other things aside from gaming.
Remember to quote or @mention others, so they are notified of your reply
Would you have any recommendations for a monitor? I was looking at the LG 32GK650F-B  monitor.
Viotek has crazy cheap and decetn 1440p 144hz monitors
Main PC:
Test Rig.
Just Sold
Ask me anything :)
Lg ultra gear monitors are fantastic. I have one of their Nano IPS ultrawides and absolutely love it. If you want a good monitor review site check out rtings.com
 Share
