Search In
  • More options...
Find results that contain...
Find results in...
More/Bigger fans, temps got worse?
Dugbuzzz
 Share
Hi there! Recently decided to upgrade some fans in my case, because I realized that while they looked good, they didn't move quite as much air. I went from some crappy fans off amazon that claimed to move around 30 CFM. And went to 2x 140MM Arctic fans that move around 70CFM each, quite the difference. Somehow, to my amazement, this has managed to make my temps worse. Both fans are on and working, and I can feel the airflow with my hand. I still have two 120MM fans for exhaust, is it possible these cannot push out the hot air fast enough? As far as temps go, in games I seem to have gained around 5C, and load temps under synthetic load went up by almost 10C. Anybody have any idea what is causing this?
Did you set a fan curve in bios?
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
I did yes, tried a couple different ones but right now it is set to turbo. Its an ASUS board.
A CUSTOM fan curve. Also are you using a fan slitter and did your case get any quieter.
AMD blackout rig
Seems to be a little quieter, and I have not set a custom fan curve no, I'll have to play around with it and see if I can make it better, any suggestions?
Your motherboard might be spinning the fans at lower rpms because they can push more air therefore making it quieter. As for the fan curve find your balance of noise vs performance.
AMD blackout rig
I put it on the standard mode, and temps seem to have dropped a few degrees, what do you think could be causing this?
I dunno I don't work on asus bios settings
AMD blackout rig
Systems specs? Which component temps and synthetic load are you referring to?
Could you post pic of the setup? Also, if you didn't know, this is the way air moved with fan:
Just saying as sounds like you are holding hand on wrong side of the fan.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Haha. They are oriented correctly. The open side is facing the outside of the case for intake.
R5 3600 seems to be the issue. All of the other components seem to have benefited from more airflow. I am using AIDA64.
The rest of the specs are as follows:
Cooler : DEEPCOOL Gammaxx GT RGB
RAM : Corsair LPX DRR4 3600
GPU : Gigabyte 1070 rev 1.0
Mobo : Strix B450-F
Mobo : Strix B450-F
Case?
19 hours ago, WoodenMarker said:
Case?
NZXT H510.
19 hours ago, Demonic Donut said:
Same clocks or are you using default or PBO? I always recommend undervolting...
I haven't messed with voltage at all, it does sit very high at idle, around 1.4v. But drops once it gets a little load. Should I try limiting voltage? It might drop my idle temps. And PBO/Auto Overclocking is off.
What rpm are the fans at during load and what fans did you previously use? What Arctic fans are you using?
The H510 was designed with negative pressure and drawing fresh air from the rear pci vents for the graphics card so it's not uncommon for additional front intakes to result in worse graphics card cooling but cpu temps should generally improve.
Arctic F14 140MM PWM. Two of them. As for RPM I will have to get back to you on that one later this evening when I play some games, do you think I should possibly have one 140mm in back and one in front, instead of both intake and see if that helps at all? Yea oddly enough the GPU benefited very much and the CPU got worse.
What 120mm fans were you previously using?
F14's aren't very well suited for the solid front panel in the H510. Try removing the front panel to see if temps improve dramatically.
Just some crappy RGB ones off of amazon. Not name brand for sure.
JI'd honestly try 1.2V max and see if you are stable. There's no reason to go to 1.4V on ryzen imo. Just wasting energy and producing heat.
Ok cool, yea It idles at really high temperatures because it seems to want to put itself on 1.4v on almost all cores, should I set the max in Ryzen Master? Not very experienced with tweaking cpu stuff.
Its what I use. Maybe one day I'll go bios level, but Ryzen Master works great for me. You just have to open the program and apply the OC profile you want to use.
Anyway, yes I'd just try limiting max voltage to something reasonable. My 3600 can do 1.2V at 4.2ghz all core and 4.3ghz all core at 1.2625V stable. I've been playing with low voltage stuff too, 3.6ghz at 1.1V is fine. Haven't done much beyond that.
Oh and make sure you are in coupled mode with RAM speed.
*Edit* also are you using all of your fans now or did you only swap? Have you tried removing the side panel and seeing what temps do?
 Share
