VS2019 - Auto convert macro to constexpr results in slower code?
amckern
When i use VS2019 (16 Preview 3) to convert macro to constexpr i am getting much slower code
macro:
#define DEFAULT_LERP_ENABLED        true
constexpr:
int             g_lerp_enabled = DEFAULT_LERP_ENABLED;
Running time:
macro:
203.03 Seconds
constexpr
339.93 Seconds
Can some one shine some light on why a constant expression is slower then a macro? This code was originally built in the 1990s (its an enhanced Quake compiler known as ZHLT) so its quite insecure.
In the first case the compiler can just substitute every occurrence of that constant with its value (in this case a char with value 1). This is the more efficient than allocating an int in memory, setting it to 1, then reading that memory location every time it's needed. There may be other subtleties that depend on the specific compiler but this is probably the main reason for the slowdown.
sudo chmod -R 000 /*
Thanks.
Is this a prompt that MS is providing in an effort to ensure that programs are more secure, or is it a part of the C/C++ ISO?
No idea to be honest, I don't see how this would be more secure though
4 hours ago, amckern said:
constexpr:
What is supposed to be constexpr about this? It's just a plain non-const int called g_lerp_enabled.
5 hours ago, amckern said:
constexpr:
To make it a constant you need to declare it as such like this :
const int g_lerp_enabled = DEFAULT_LERP_ENABLED;
There is a huge difference between a variable and a constant. When C# build the code the constant value will be computed once and then it will replace the constant name everywhere with the constant value making it hard compiled into the code using it. Your current variable will be references to every single time it is used.
I'm just using the auto convert. I'll replace the function with a const int and see how it performs in comparison to the curent numbers.
Its also C++, not C#
Edited by amckern
using not useing
same thing for C++ plus it's the same syntax
