NZXT H510 Elite with a 240mm AIO
Solved by WoodenMarker,
You can use both and it may be a bit tricky but the front cooling tray should make this is a bit easier. Attach the 240mm first and the 140mm fans afterwards.
Here's an example: https://pcpartpicker.com/b/3sRJ7P
lexiq ·
Posted in CPUs, Motherboards, and Memory2 -
Onions ·
Posted in Linux, macOS and Everything Not-Windows2 -
1
SyndiShanX ·
Posted in Audio8 -
Nexxus ·
Posted in Programs, Apps and Websites3 -
ds5018 ·
Posted in Troubleshooting5 -
5
Muzzy2002 ·
Posted in New Builds and Planning5
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
