nvidia rtx voice Would RTX Voice work on Pre-Recorded recordings?
If you use Voicemeeter mixers it's easy to tell RTX Voice to use one of the virtual output tracks, assign the RTX Voice mic to one of the real inputs, set your default audio out on Windows to one of the virtual input tracks and your real audio output to one of the real output tracks.Send the virtual input (default audio out) to the virtual output (RTX voice), and the real input (RTX voice) to the real audio out (speakers).
If you use Voicemeeter Potato you get 3 virtual input tracks so you can use Windows' per app output selection to use either of those 3, so you can send some straight to speakers and some through RTX Voice.
It's funny to launch a movie and get nothing but speech out
I notice I prefer RTX voice noise suppression about half way, not full...
