Buying new monitor going from 1080p 120hz TN panel to 1440p
Solved by Imabigmac,
http://www.xbitlabs.com/articles/monitors/display/acer-gd245hq-lg-flatron-w2363d_4.html, that's what I found, they claim it is anyway. I haven't been bothered by the flickering of my pb278q. I think if you stare at 27inches of bright light you get a headache pretty fast anyway.Not as far as i know. At the time i bought this monitor i didn't look for much else than the 120 hz tag and low ms. But as i look up the monitor now i can't find anything confirming it having PWM
If it does that is a relief since this monitor haven't annoyed me with any flicker.
