RAM Not Running at Correct Mhz?
Hello all,
I just recently added an additional 16GB of 3200MHz RAM to my gaming rig (for a total of 32GB, all at 3200MHz). And Windows Task Manager, my BIOS, and even CPU-z are telling me that I'm not getting 3200MHz across the board. In addition, my bios won't let me run xmp. It crashes and has me revert to previous settings.
The ram I had initially was Corsair Vengeance LPX (2x8) 16GB 3200MHz, and I added Corsair Vengeance RGB Pro (2x8) 16GB 3200MHz. I'm wondering now, if this was a rookie mistake, and I should've just gotten more LPX instead of the RGB? But the MHz is the same, and the latency numbers are also the same.
System hardware is as follows:
Core i7-9700k
MSI z370 SLI Plus
RTX 2070 Super FTW3
If anyone has any advice on how to fix this, please let me know. I still have time to return and the ram I got and swap it for the same ram I had initially.
Thanks!
The only thing I can think of is the system is trying to be safe because you have two different ram kits. That is the only thing I can think of
this can occur in various reasons. can you try wiht onlu LPX or only with the rgb sticks and run XMP?
of course your system might not like the different models, but my old system ran with them, so there can be a problem with your ram stick too.
update bios and other drivers.
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
What speed do these show?
If it's anywhere between 1000 - 1200 or anywhere from 2133 - 2400 Mhz, it's indeed not running at the same speed.
It's probably a case of these RAM sets not having the same XMP profile, meaning you either need to dial in the speeds yourself or return the RGB set and get the same LPX set once again.
d
Ryzen 3700x, RTX 3080, 32GB Ram 2x16gb Corsiar Vengance LPX ddr4 3600,2TB 970Evoplus m.2 nvne, MSI B450-A PRO MAX, Windows 10 64 bit ,AOC 1440p 32 inch 144hrz, AOC 1080p 24 inch 144hrz, Corsair RM850 power supply
Try setting an XMP profile then manually changing the DRAM voltage to 1.45v, if that works try 1.4v. 1.35v is the default XMP voltage.
14 minutes ago, pokemark17 said:
Try running user benchmark should tell you under the memory catagory, memory often shows up as half
Userbenchmark is utter trash.
dont mix ram sticks, even if first timings are equal ,secondary or tetriary timings are never the same,   ul get stability problems wether its in high or low profile problems shown
Thank you all for the replies! I took out the RGB memory and ran only the LPX ram, turned on XMP and forced the LPX ram to run at 3200MHz, and it's working! Task Manager says my RAM is running at 3200MHz now. So all that's left to do is return the RGB RAM and swap it to LPX.
Thanks again for all the advice!
  • 3 weeks later...
As a resolution to this post (I know it's a late one), I did get more LPX RAM and now I am having no issues regarding RAM.
Thanks for the help and advice!
