TX650M V2 loud fan speed high
Hi guys
I made a post a while back about my tx650m being the loudest thing in my system at idle, which is still true, but it has definetely gotten louder and the fan is spinning faster than before and I cannot for the life of me figure out why.
It's just loud and annoying
It's loud enough that I can hear it whir a bit through earbuds, which wasn't the case before
What should I do with it? Try to suck/blow out dust with a vacuum cleaner while holding the fan? And if that doesn't work?
Thanks for your advice :)
1 hour ago, Yasin40 said:
Hi guys
It's a TX650M V2?
Are you sure?  I don't believe there's any such thing.
There was the original TX.  Then TX V2 (Bronze, except for the 950W which was Silver).  Then TX-M (Bronze).  Then TX-M went away.  Then TX-M came back as a Gold PSU to replace CS-M.
1 hour ago, jonnyGURU said:
It's a TX650M V2?
yeah sorry i have tx650m gold
bought last year
i thought it was called the v2 oops
Ok.  If it's "clean" (not clogged with dust), it shouldn't be getting "louder with age".
If it's only a year old, you should just contact Corsair and get it replaced.
