Is there a thing such as Too much power can kill my board?
Solved by Fasauceome,
4 minutes ago, Feyza said:I aprreciate your help but,
My motherboard is a DELL 0GXM1W - says CPU-Z
So when I search for cases, do i search for Full ATX, Micro ATX, you got the point....
micro ATX cases should fit, since DTX is not very tall and is no wider than micro ATX. I wish I had a spare case on hand to test with myself but when I measured the motherboard, the hole spacing was just right. So, any good ATX or micro ATX would serve you.
One case that I saw with a USB 3.0 port and some decent looks/airflow is the Deepcool MATREXX 30, give it a look.
