What order should I build my pc in?
Solved by DailyProcrastinator,
3 minutes ago, DriedSponge said:I've never built a PC before and I'm wondering what parts to install into the case first. Is there a specific way that helps keep everything organized or does it depend on what parts you pick?
Yes, I suggest watching some tutorial vids on how to do so.
txmatt1214 ·
Posted in New Builds and Planning3 -
2
2
Nevan Nedall ·
3
Littellittel ·
Posted in Troubleshooting0 -
4
ShadowBroker50 ·
Posted in CPUs, Motherboards, and Memory0
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
