Question re. Power Supply. Pls. help.
Solved by mariushm,
Even a 500w power supply will be fine, as long as it can actually provide the advertised amount on the 12v output... aim for at least 400-450 watts on the 12v output.
Ryzen 2600 : up to 100-120 watts
RX 580 : up to 200-225 watts
RAM : up to around 10 watts
SSD: 2-5 watts
Hard drives : less than 10 watts each
Motherboard : around 10-30 watts
