Xeon X5660 Overlcoking Help
@Patrick Samuel You may just have a bad chip, or poor cooling / contact with cooler.
Things to try-- raise BCLK higher with EVERYTHING else turned down. In other words, aim to get a ~200-205 BCLK stable, if you can (adjust QPI voltage), with CPU multiplier down at ~10 and Mem down at ~6. The point here is to isolate each specific variable so that you only tinker with one at a time. Important to note is to do this starting from stock voltages too. Write down your settings now and then just hit 'reset to defaults' in bios if all you've tinkered with are the voltages and speeds. You want to do this procedure from a clean sheet reset.
Then try keying in a memory multiplier of ~8, should put you at 1600 MHz speed. I don't notice a major difference between 1600 and above, but 1000 to 1600 would make a difference. This is contingent upon your modules working nicely.
Then dial in your CPU multiplier, and go through the whole process again. It's laborious but effective.
Other things to note-- per the techpowerup article, you want a 2:1 ratio between QPI speed and UCLK (uncore clock). The higher you can get uncore the snappier your system is. This is driven by BCLK. Generally you also want a 2:1 ratio between uncore clock and memory speed. In other words, for QPI : Uncore : Memory, you'd aim for 6400 MHz / 3200 MHz / 1600 MHz, which is super easy with a BCLK of 200 and respective 32 / 16 / 8 multipliers.
You may be limited on BCLK by your dissimilar memory modules.
Additionally, X58 runs significantly better with higher BCLK and lower CPU multipliers. Aim for a stable fast BCLK (I suggest starting from stock per method above with CPU/Mem mults reduced, incrementing 10 MHz until ~180 then 5 MHz above, stress testing each setting), then QPI/Uncore/Memory, then finally CPU. One last thing to note-- there exist 'BCLK holes' where say from 180 to 195 the system just isn't stable, but magically is on both sides of that region. It's not the same for each board (hence the importance of messing about with each variable independently), but these do exist. Mine hated anything in that region but is rock solid way above it.
My X5675 is running 215 BCLK and 21 multiplier. It'll do a 23 mult happily enough, but there's not much performance benefit to be had between 4.5 and 4.7 GHz-- don't be target fixated on a high CPU Mult to the detriment of the other settings.
I would focus first on getting a matching set of RAM over swapping CPU, unless you have funds to do both. I'm not convinced your CPU is bad. All else equal, you will get more performance out of the system by tuning the uncore than by more frequency. If you can do 4.5 GHz, great, but if you can do 4.2 with a screaming fast uncore, that's likely to be better. Right now you have neither, so got some tinkering to do!
@Zando Bob this is making me want to just write a procedure out for the main thread, such that we can just hotlink it. And to say F it let's OC the SR2....on water.
EDIT couple things I missed previously--
Your CPU is idling at 48 C in bios. Your cooling is not working. More CPU Vcore is more heat, while more QPI volts does not necessarily mean more heat. More reason to focus on BCLK overclocking. Also the X5660 doesn't tend to go much above 4.2 without a dialed in high BCLK setting since it lacks some of the memory and cpu multipliers of the higher binned chips. It CAN do it, but it really needs BCLK help to get there.
Finally, you might find this post helpful (my OC settings) in the Intel HEDT (primarily X58) thread on the forum here. There is a TON of good info in the thread:
