Correct fittings for 10/13 flexible tubing?
Solved by Enderman,
The description or the title of the product is wrong.
You'll have to contact them to find out.
Also XSPC fittings are pretty bad, you should be buying good quality fittings like bitspower if you don't want to risk a leak.
TurleyV16 ·
Posted in Troubleshooting1 -
Rumman ·
Posted in Troubleshooting2 -
poly ·
Posted in General Discussion4 -
4
skayqz ·
Posted in Graphics Cards2 -
3
3
bat_verified ·
Posted in New Builds and Planning12 -
8
3
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
