Monitor white flashing line
orcanice
Last night my monitor suddenly started showing a white flashing line
 Here is a video showing the problem.
All text under the white line isnt looking sharp anymore.
Have anyone seen this before? and does anyone know if theres a fix.
Step one:
Swap video cables.
Step two:
Boot to BIOS, see if you still get this issue.
If you do, then it's (probably) a failing monitor
Step three:
Report back
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Just now, Radium_Angel said:
Step one:
Swap video cables.
Step two:
Step three:
Report back
The problem isnt with the pc. because the line is there if i turn the monitor on without any display cables.
So the monitor broke
F@H
GPD Win 2
I actually had this problem with an old monitor and it turned out it was dead/dying. Mine had a hot-spot and warping in the center that was clearly visible if I used a black wallpaper. Maybe try changing your wallpaper to a standard black one and checking that.
Thanks for the replys and tips guys.. guess its time for a new monitor then..
Currently looking at these
acer predator xb272 or benq zowie xl2740
if anyone got and suggestions about these i would like to hear them :)
Well you didn't say that before, but yeah, bad monitor.
