storemi HELP NEEDED TO UNINSTALL STOREMI
The knowledge base for FuzeDrive is also applicable to StoreMI. See this article:
https://desk.zoho.com/portal/enmotus/kb/articles/uninstalling-fuzedrive
The expert version: Your drive is now in a RAID-like configuration, where your LBA is virtualized, and a VMAP maps your data to the LBA of the underlying disks. Where we do provide a feature to "Remove Fast Media", i.e., move everything to the slow drive, assuming you have the space to do so, your drive is no longer linear with LBA and will still require the StoreMI driver to access the data even if there's only one drive in your tier.
In short, you'll need an extra disk or cloud storage with enough capacity to move all your data to, then clean the drive, and move your data back again. Note that the upcoming FuzeDrive 2.0--and, at some point, we assume StoreMI, though if/when is up to AMD--adds a feature to re-linearize and "unfuze" your drive. That release is some months away, however.
