Pc build for £2500
Solved by Alienized,
3 hours ago, boggy77 said:you can, but I wouldn't recommend it. the bitfenix whisper is one of the best quality PSU's out there, 650W are enough and it's cheaper than that EVGA PSU.
look it the PSU tier list in my signature to see how the whisper is in tier A+ and the GQ is in tier B+
Ok i will go as you say...if the pc will be in flames in 3 days i am blaming you
Cheers mate
