Need help picking a 1tb ssd
Solved by NewMaxx,
Check the link in my signature, there's more resources there in my subreddit. If it's to be a workspace drive and it's going to be filled up often with plenty of writes, you probably want to avoid anything DRAM-less and also drives with QLC or large SLC caches. For the most part that would leave the WD SN750 as the best candidate - this has been <$130 lately at 1TB. E12-based drives would be suitable budget alternative. Again, check my resources.
